Originally Posted by whokilledthejams
If I could find the name of it, I'd recommend the 3M product that EZPass gives you to affix the tag to your windshield. It's sort of velcro-like, in that the two sides physically grip each other. They're a semi-hard plastic with tiny little light bulb-shaped prongs that grip each other, and both sides are identical. I figured a while ago that it would be a great way to affix wheel skirts, but I don't want to arouse suspicions by requesting samples to affix a dozen EZPass tags for the two vehicles on my account.
I found mine at Target. It's hard to find but it will absolutely hold nearly anything. I found it years ago at Kmart. I have looked ever since and finally found it at Target in the hardware section. If you find it grab a bunch. It's likely the next time you want it you will hunt for it forever. If you ask for it everyone will think you are crazy.
All that is on the package is Scotch 3M Reclosable Fasteners part# RF9730 UPC# (bar code) is 0 51131 64284 3
3M RF9730 RECLOSE FASTENER CL
