Trucks tend to be over powered and putting smaller tires on them usually hurts milage.
I don't think any one has put smaller diameter drive wheels on anything and seen an improvement with out regearing the differential or transmission.
Then when you put smaller narrower tires on you lose load capacity. If you go with inch narrower and smaller diameter tires you can forget about that 2,000lb load rating.
You can get away with smaller tires on a car, be cause you usually don't carry that much weight.
Put load range C 31x10.5 tires on. Or load range C 30x9.5 tires.
I went from P235/75R15 tires to 31x10.5R15 tires on my suburban back in 2008, milage did not suffer, may have even gone up a little. It rode much better.
I plan to put 30x9.5 H/T tires up front, and leave the 31'' A/Ts on the back since I have a 2wd. I don't have to worry about over loading the tires any more.
