Hello, just yesterday I took Yolanda the Honda ('02 accord coupe) to a local shop to take care of a hub bearing that had gone bad in the front right wheel. Once they got it on the lift, the reason the bearing was going so quickly became apparent. The sub frame in the front right corner was cracked in at least 2 places and broken clean through in at least one.
The cost to repair everything (right hub bearing, right ball joint, evap issue, and cracked frame) is going to run nearly $3,000
essentially what we paid for the car. I'm only 18 and don't have that kind of money to put into the car if I could spend that or a bit more to get something with a smaller engine and a blessed manual transmission. Right now I have my eye on an 1997 Honda civic dx hatchback that I believe would be a very good starting point for an cost effective ecomodded car. In roughly 2 months I am leaving home for a cross country backpacking/survival camping trip that will last at least a year. I will be using the car to drive from wilderness area to wilderness area/trails that I would like to go to. my needs from the car are getting from point a to point b in geographic conditions ranging from Alaska to the high desert. tentatively I have my eyes on a 1997 Honda Civic dx hatchback. I am all ears, any input you can give would be much appreciated.
