Old 07-29-2014, 12:17 PM   #15 (permalink)
hertfordnc
Originally Posted by P-hack View Post
The camber of the fan is designed to pull air in, not be pushed by incoming air, if you are thinking you are gonna approach 57% ME hertford, then you are in for a surprise. Well you are looking for a couple watts of "free" power on a 3.5 ton vehicle, so there is that too.
Yeah, well, it's definately not a prius. But my other car is a civic hybrid so my fleet average is still pretty good and my cost per ton mile is batter that most of you
I have no particular expectations of the results. I came up with the idea absent much knowledge of the physics involved and other people speculated on what my results might be.
I'll start by adding the fans to see what that does. I expect 1-2 MPG in the summer when the fan runs a lot. THen I'll experiment with powering the fans from a battery not connected to the alternator. If that provides an improvement then I'll figure out to charge the battery from either solar or the spinning of the fans.
