Welcome!
There are several of us on here that have 7th Gen Civics. Mine is an 05 Sedan with a 5 speed.
As far as I know, the only engine that will bolt to a 7th gen transmission is a D17. I don't think a D15 will bolt to your transmission. But, you could always swap out the transmission too. Is this an auto or manual? If you have a manual and swap in older generation's manual, you will be going from a cable shifted to the rod shifted.
Then there is the ECU to reprogram and replace. A swap might end up costing more than the MPG increase is worth. I'd throw in a junkyard/Craigslist D17 (new timing belt, water pump, etc) and call it a day. If you have a manual transmission, you should be able to hit 40 MPG at a minimum. Up until it got blazing hot here and I started using the AC, I was able to keep a 40 MPG average in traffic.
But, if you wanted to do something different, grab an EX/HX motor and HX ECU (can 7th Gen Civic's ECU even be swapped? I am thinking out loud...) and throw it in your car. Then, you can have a lean burn sedan!
