I just reused my trans fluid after my timing belt swap. I replaced the axle seals and needed to drain it. I used a clean pan and tried to keep the brass synchro dust from going right back in the transmission.
What's the worst that can happen to my 107,000 mile transmission? It wears out faster?
I'd probably reuse the engine oil. Just keep it clean.
