Originally Posted by Old Mechanic
Check each wheel for brake drag. Using the emergency brake adjust the rear shoes. Most brake issues will be in the front discs. Calipers tend to get stickywhen they have not been serviced recently. The pistons will not retract enough to minimize drag. When I had my shop I just went through the brakes completely, surfaced rotors a drums and made sure the caliper pistons retracted properly.
regards
Mech
I'm pretty confident regarding the pistons on the front brake calipers, as I replaced everything back in April. However, I am intrigued about using the emergency brake to adjust the rear shoes. Is that the same procedure that this guys is doing in the video or can you elaborate upon the procedure more? Thank You.
