Originally Posted by Old Mechanic
I use Mobil 1 5w20 in the Fiesta. I change the oil at 7500 and use an extended life filter which I change at 15k, every other oil change. I also only fill to half of the low to high range on the dipstick. Last 5 quarts was $22.26 at Wal Mart, so it's about $26 per change with that method. The Fiesta will drop to the add mark at 7500 when I change the oil, so I never add any oil. The slightly lower oil level saves me a little oil and the oil warms up faster.
regards
Mech
How much oil does the Fiesta hold? The Civic only gets about 4 quarts. I am nervous to run less than that, but I guess it would be fine.
I think my Honda manual recommends 10,000 miles for oil and 20,000 miles for the filter. Honda decided to put the oil filter on the back of the engine and then added a brace from the block to the trans. So, whenever you take off the oil filter, oil goes down to both control arms and leaks everywhere.
