Originally Posted by Cobb
Why is your Silicon so high?  Did you check to see if your air filter has a hole or vacuum leak somewhere?
I was going to sneak in a jab about running a K&N filter until...
Originally Posted by sarguy01
I also have a K&N filter, so that might have something to do with it.
Sarguy, I run a Honda 4-cylinder engine 12,000 miles on the same oil, so you should be good. I'd do something about the Si level, and by do something I mean ditch the K&N.
What did the report comments say?
