Old 07-30-2014, 03:31 PM   #11 (permalink)
freebeard
Anyway here they are, first did I use the template correctly?
...I think it would make a really good mount for a kammback idea I have.
Keep in mind what the Template looks like from the front or back. So what's the Kammback idea look like?
The dust shield would basically keep the wheels clean and prevent air moving in or out of the wheel disk. Just make it as much like this as you can.
All the attention is given to smoothing the line from the middle of the tire sidewall to the face of the disk. The rim is wider than the tread and the disk laps over the tire sidewall so it's one smooth curve from one side to the other. It even has a neat little access panel for the lug nuts.
aerohead (07-30-2014)
