I'm almost done adding a new connector with voltage divider. So, Flores' rx pin coming from off of the board goes straight to the microcontroller, and is going to be a well behaved 5v signal? Or do I have Flores' RX signal from off the board go to the max232? And the tx signal coming from the microcontroller to off of the board will be a 3.3v, skipping the max232 altogether.
