Old 07-31-2014, 09:13 PM   #47 (permalink)
oldbeaver
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Diesel Flow metering cheap
Originally Posted by oldbeaver View Post
Hello old diesel fellows,
There is guy in India who sells a complete system consisting of two diesel fuel flow meters (one for supply and one for return fuel) and a LCD digital display that shows a several consumption values, including the difference between the two if I am not wrong. Fuel consumption in liters/hour.
Fuel Consumption Meter - Diesel Generator Fuel Consumption Meter, Automobile Fuel Consumption Meter, Vehicle Fuel Consumption Meter and Fuel Consumption Calculator Manufacturer & Exporter from Mehsana, India
To calculate accurate fuel efficiency (mpg or km/liter), the only thing missing is to take the speed signal existing in our cars (or generate it if not), which is in miles/hour or km/hour, and divide by consumption.
The system looks robust. It should allow to get fuel efficiency in km/liter (or miles per gallon) with very little programming. Maybe it can be done using the elabtronics kits:
AutoSpeed - eLabtronics EZ System, Part 1
The result should be shown in the very same display of the indian system.
Someone will take this project? It looks very attractive and possible.
Oldbeaver
Last minute: I got the price: USD 650. Too expensive I think.
I found a much cheaper set for diesel flow metering in a IDI diesel:
Flow Sensor
Look for "gasflowmeter", just arrived, they say.
It has a digital display and one flow meter. We need to buy the second flow meter, and a processor to calculate difference between supply and return fuel, and combine with speed signal. Not easy for my digital electronics knowledge.
I cannot guarantee duration of this flow meters, but if the system works, one can replace them later if they fail.
Oldbeaver
Mercedes 300 D turbo 1993
