Old 08-01-2014, 06:32 AM   #34 (permalink)
RedDevil
90 day: 54.93 mpg (US)
You probably don't need a full size rear window, a half size would give you a clear view straight back from the center rear view mirror.
Maybe you can use what's left of your acrylic kammback.
I've cut my acrylic upper grill block (not fitted yet) with a Dremel (like) mini tool and its small disc blade cutter. The acrylic will melt (and stink! Do it outside) but not shatter.
You need a lot of patience though and a steady hand.
I shattered the little disc just before finishing the cut and was too lazy to replace it and continue. Well it is too hot now for a full grill block anyway...
