Old 08-01-2014, 07:45 AM   #15 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by wjohn View Post
I'll admit to being slightly confused about current LT designations. General's site has a spec list for the Grabber that I will post in a minute after I've reached my magical "5" post count that allows me to post links. They have three different 235/75R15 tires, with one of them being designated as an "LT" that, most notably to me, weighs .6 pounds more than either of the other 235s. Max load is close to 2000 pounds for each of the tires. If I go with these tires, I'll probably go with the 109T-rated mainly for the higher PSI rating.
To explain the 3 different tires:
One is an LT tire. LT is a designation about the relationship between the load carrying capacity, tire size, and inflation pressure. As a general rule, LT tires use more inflation pressure to carry the same load compared to P type tire - BUT - P type tire do not carry as much load.
One is a Standard Load (SL) tire - and since they didn't put the "P" in front of the tire size and they are a European based company, I assume they are using the European tire standard.
And the third is an Extra Load (XL) tire. In theory, this XL will have ever so slightly more RR and the SL - because it has ever so slightly more mass.
And just so you know, the maximum tire pressure listed on the sidewall isn't a rating. It isn't anything other than an advisory not to exceed that value. It has no relationship to what pressure works best for your vehicle, because the tire manufacturer doesn't know the characteristics of your vehicle.
The vehicle tire placard, which lists the original tire size and the specified inflation pressure for that size, will be located on the door or doorframe (and since you vehicle is older than a 2008, it might be in the glove box). You should reference that as the vehicle manufacturer did all its testing at that pressure and set the vehicle up to perform a certain way. Changing the inflation pressure is going to change the handling characteristics of the truck, so be careful here.
And perhaps it might be appropriate to talk about the differences between an d"LT" tire and a "P" type tire.
You might think that these designations indicate the type of vehicle the tire is designed for - and you would be sort of right. But what those designations really mean is the tire standard the tire manufacturer is working with. P type tire designations are low pressure tires designed for lower load carrying capacity. In the same size, an LT tire can carry more load, albeit with a higher inflation pressure.
One quirk is that P type tires have to have theiir load carrying capacity derated by a factor of 1.1 to be used on a pickup truck, van, or trailer - where an LT already has that factor built in.
But LT tires are built out of different materials than P type tires - typically not good for rolling resistance, because LT tires carry much more load for a given size because of the higher inflation pressures used. This is more evident in that larger sizes - like an LT245/75R16 Load Range E which has a load carrying capacity of 3042# at 80 psi where a P245/75R15 SL (Standard Load) has a load carrying capacity of 2271# at 35 psi, which would be derated for pickup truck usage to 2065#.
Because of this higher loading, the materials used in an LT tire are more resistant to a phenomenon know has compression set - where the rubber permanently deforms due to load. What comes with that change of materials is a higher RR.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
wjohn (08-01-2014)
