Originally Posted by California98Civic
It should help emissions, which can be a cha)enge with these older cars. I was close to the max limit in one category two years ago. So I'm going for overkill: since then an O2 failed and I replaced both, but now I plan to change the oil and its filter, the spark plugs, and the air filter in the day or two before the test too. I'm debating whether to clean the CAT with citric acid before the test, or wait and see if I fail, then clean, then try again, then buy a new CAT if I fail twice. The car never has failed, but for some reason the test makes me nervous, lol.
When I did my smog not even a month ago, I wasn't even close to failing in any category so I think I'll hold off on doing it. However I am getting really weird power losses still at takeoff, I think I'm gonna change my fuel filter and see if it helps. Meh.
