Originally Posted by Old Mechanic
Make sure you tighten the valve lash lock nuts more than the valve cover bolts!
On a 1990 CRX, the torque spec for both is (IIRC) 10 lb-ft. Kind of a pain to use a torque wrench on the jam nuts, but I sure don't have a feel for 10 lb-ft...
-soD
