Originally Posted by MPaulHolmes
***breathes a huge sigh of relief*** Haha. There is actually quite a bit of filtering on the throttle. It averages out about the last 128 samples or so. The ohms must have been jumping around pretty significantly for you to feel it. I'll send the hex file for the fix that is probably not a concern, but could be at least in theory. It would just be a single extra line of code.
You could watch the resistance change on an ohm meter as you move the throttle. My guess is it jumps around quite a bit.
My DVM isn't fast enough to catch them.
It feels like drop outs. Maybe ramping the power down as we discussed and rejected earlier would mask them.
