Old 08-03-2014, 03:07 AM   #15 (permalink)
mistareno
I'm a little restricted in overall shape by how far the solar panels can curve.
That shape is probably getting close to the curve limit.
I legally need the front to be section to be above 400mm so I can fit the headlights and Number Plate in the front curve. The front will be a tight radius curve of lexan. I can't really fit the headlights anywhere else with the solar panels.
The little solar panels are just to fill in the gap. I'm sure I can find something in a similar size or even just make my own.
I was planning on running 13 inch wheels with a 135/80R13 tyre which is why the wheelbase looks long. It's pretty much to scale with that tyre.
The Following User Says Thank You to mistareno For This Useful Post:
aerohead (08-04-2014)
