Old 08-03-2014, 01:17 PM   #10 (permalink)
Stacygifford
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
Originally Posted by iveyjh View Post
I have been running up to 22.4 to 1 AFR in my 2000 Metro for a couple of years with none of problems you speak of. I run an EGT sensor and have found that running lean actually decreases the combustion temps. A little lean from stoich under load produces hotter temps.
An EGT gauge/sensor would be a must have. The temps under load is the concern. For normal causing (for someone who drives economical) it wouldn't cause a problem.
However the problem arises whenever aggressive driving styles come into play.
