Old 08-03-2014, 05:06 PM   #3 (permalink)
MPGomatic
Needs More Duct Tape
MPGomatic's Avatar
Slambo - '99 Honda Civic HX
90 day: 44.21 mpg (US)
Originally Posted by California98Civic View Post
Are you certain you want this? Your HX probably already has two. And the ECU already monitors the AFR on the HX using a wideband sensor. You can read that data using an ultragauge plugged into the OBD2 port. You're already aware of that and there's something else you are trying to do? Run a SAFC2 or some other Apexi or like unit? Sorry, just rying to help...
Yep, the D16Y5 already has two 02 sensors. I have a sweet high-end air/fuel gauge sitting on the shelf. It would be cool if I could simply tap into the existing wideband sensor, but it doesn't sound like that's an option.
The goal is to put the a/f gauge line of sight, while running Dash Command on the JVC flat screen head unit (via AppLink).
I have bluetooth and wifi dongles, as well as a scangauge and hardwire, but how many things can you plug into the OBD port at once? (I've never been able to get two units working with a splitter.)
