Old 08-03-2014, 06:06 PM   #643 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
It's not like you owe me anything, I'm just curious. Is it compatible with polyester or epoxy resins?
The pieces aren't big enough to really do anything, but you could lay a rod along the edge of a slab, wrap it wih the textile soaked in resin; and then when it cures hit it with a hammer. You can't not learn anything.
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
sounds like a good test. will try it.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
