Old 08-03-2014, 07:06 PM   #118 (permalink)
Frank Lee
Steel belts are comprised of cords. You have noticed that they deform at the contact patch; why wouldn't they also deform in the other axis?
I'm all for higher than mfg recommended pressures but I'd say a person needs to monitor the center tread wear vs the edges and adjust psi if needed.
roosterk0031 (08-05-2014)
