Old 08-06-2014, 04:11 PM   #400 (permalink)
freebeard
Services | REM Surface Engineering
REM Isotropic Superfinish
REM Surface Engineering’s ISF Process produces a surface that has several key advantages over other “superfinishing” techniques. The resulting surface is asperity free, with a non-directional (isotropic) texture. The surface has an increased bearing ratio and enhances the lubricant retention properties of the mating surface.
Services | Weddle Industries | High Performance Driveline Components for Race Vehicles | Off-Road Transaxles, Clutches, Gears
In-House REM Polishing, Magnaflux Particle Inspection and Shot Peening
Not that I can afford this stuff, but it's there.
