Old 08-07-2014, 02:09 AM   #10 (permalink)
radiantthought
radiantthought's Avatar
Leaf on the Wind - '13 Nissan Leaf
Why do they use motorcycle tires when the profile isn't utilized? Motorcycle tires are expensive, and if the profile isn't used, will wear out quickly.
You must be talking about the eco-exo, the kandi viper uses 165/70R13 tires all around. The reason I'd guess the eco-exo uses motorcycle tires is because its steering system is designed to use the front end from the suzuki bergman. They seem to like to use as much of the donor vehicle as possible, so that falls in line with that.
