Old 08-08-2014, 12:36 AM   #116 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by California98Civic View Post
At a 9.4:1 compression ratio I think you should see about 200 on your test, ideally. I've seen people not complaining about 180+ much. Adjusting valve clearance, I read, by increasing it--perhaps to max spec.--can help with compression. Did you check clearance on #1?
All I used was a compression tool from O Riley and hooked it up to the spark plug holes. How do you adjust valve clearances and all that stuff?
