Old 08-09-2014, 10:07 AM   #194 (permalink)
The donkey CRX
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Why do you fill up when the tank is half empty?
I just got this question in a PM, so I thought I would answer it here in case anyone else was wondering.
My first reason is that modern fuel pumps are located in the fuel tank so the gasoline can help keep the pump cool. I burnt up a fuel pump once when I ran my tank down to almost empty on a 100 degree summer day. Since then I always keep the tank half full. I figure even when it is not real hot outside, the fuel pump will be less stressed if it is kept cooler. Replacing a fuel pump on a modern car is very expensive, messy and time consuming!!
The other reason is I live out in the country and in case of an emergency may need to drive several miles without time to find gas.
The Following 3 Users Say Thank You to The donkey CRX For This Useful Post:
j12piprius (08-09-2014), mikeyjd (01-07-2015), OG VX (12-15-2014)
