Originally Posted by Hersbird
The CdA and efficiency have nothing to do with hybrid part 500 extra pounds does. Basically they should make a non-hybrid Prius for highway commuters. I think that is what the new 1.0l fiesta is going for. I bet in the hands of a hypermiler it goes 55mpg highway or more pure stock, then add some aeromods. They start about $17,000.
Fact check. The hybrid system in my Insight consists of the electric motor/generator connected to the crankshaft, a 27 kilogram hybrid battery, some cabling and some electronics. That is all. I doubt it weighs more than 100 pouns all combined.
Then, it does not need an alternator nor flywheel (the electric motor does that), it can do with smaller brakes, a smaller 12V battery, a smaller engine, a smaller fuel tank, you name it.
All in all it could be lighter, not heavier, than a non hybrid with like performance.
Weight is not an issue on true hybrids.
At my office I regularly park next to a 1.0L Fiesta Ecoboost.
I wonder how good my FE would be if mine were as small as that. But I'm glad it is not that small.
There is a hybrid of comparable size and weight: the first gen Insight, it too has a 3 cylinder 1 liter engine.
![](https://images.spritmonitor.de/544051_25.png)
![](https://ecomodder.com/forum/fe-graphs/sig7127a.png)
