You need to make sure the egr passageways are functionally clean. Probably nothing wrong with pulling the manifold, replacing the lower injector seals (vacuum leak potential). Clean the connectors on the injectors. Make sure everything is in good shape, if you have the talent and determination. You might blow past 50 MPG.
regards
Mech
