Originally Posted by California98Civic
But when I got in there, I found a couple valves far too tight and most tighter than they could be.
Interesting, I always thought valve clearances would loosen over time as parts wear & noise would increase? Also thought if valve clearances are adjusted too tight, the risk of burnt valves increases due to inadequate heat transfer to the head?
