Originally Posted by cowmeat
Probably from all that EOC & P&G with the lights on
I go to work way before sun-up, so the entire time I'm P&G or EOC in the mornings it's draining the battery. Once in a while it needs a push, but I bump start as much as possible , so that helps
Oh no not at all, it died because I did a compression test on Thursday before I went on vacation and I put the spark plug wires in wrong. I killed the battery trying to turn it over to start it before I found the error of my ways and fixed it. I then jumped started it and drove it around the block to give the battery a little bit of a charge. When I got home Sunday I forgot, drove it to work and sat for 8 hours in my car with the inverter plugged in charging my phone and laptop. Lol.
