On my DD Wrangler I had the trans bracket replaced with a lighter one, factory recall. All I do is run it low on gas, no more than $30, as it is kinda bare bones to begin with.
My 69 Charger RT has manual steering & a modern aluminum manual master cylinder I switched out. Then I removed the radio and speakers,heater and all ducting + hoses and added radio block off plate. Scraped as much under coating as possible and seam sealer inside out. Aluminum intake is on and water pump housing and pump are going in this fall.
No this ride is not a MPG KING or a stripped out hulk either, I am making it how I would have back in the day.
