Originally Posted by RedDevil
So... bump start diesels in third gear
I think 3rd or higher is always a good idea if you can get enough speed, because when you're driving the engine with the wheels not only the mechanical advantage is reversed, but some types of gear meshes have lower efficiency being driven in reverse.
