Originally Posted by Arragonis
DPFs are now part of the emissions test which is part also of the annual safety (aka MOT) test for vehicles over 3 years old. Basically like catalysts if it was fitted when the car was sold it must be fitted when the test is done and be working - not sure how they confirm the last bit though..
Exhaust soot test.
On Hägar, the MOT usually repeated the soot test because it showed 0 on their equipment.
Many cars with DPF will still show some very low soot readings - right at the lower detection limit. But not Hägar ...
But then, I'd drive around until it had completed a DPF burn-off cycle, before going thru MOT.
