Old 08-12-2014, 06:37 PM   #10 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by NothingFace View Post
All this stock and at 32 PSI wich is the recomended tyre preasure.
The AX is very light, so increasing the tyre pressure may make it bounce which isn't good for handling.
You could increase the pressure bit by bit and see how it behaves.
But that way, you won't get great instant changes in fuel consumption.
I'm planning to make a small Kammback like the Citroen AX Eco concept,
That'd work best when you do enough kilometers driving at higher speeds.
Driving around in the city, it won't have much effect.
In the city OTOH, reducing weight will have more effect.
and maybe some wheel covers on the back,
A cover to go on the wheels, or a cover for the wheel opening in the car's body ?
Citroen has already closed up the upper part of the wheel opening.
not shure if I can put some flat trim on the alloy wheels what do you think ?
It's possible.
Forum user Vekke sells some stuff to fit plastic disks to alloy wheels using zip-ties.
