Old 08-13-2014, 02:38 PM   #17 (permalink)
jamesqf
...none of the other computer repair people responded directly to the original suggestion, that the hard drive moved its read heads in anticipation of a crash.
Maybe because it's likely that the hard drive was actually powered off at the time. Unless you're running a program that does a lot of disk I/O, the OS typically reads the program into memory, then shuts off the hard drive to save power.
Obviously, that power button only has one job, and fails.
Shut it down with the shutdown command - I'm not sure of the Windoze equivalent, but I think it's on the "Start Menu". That makes sure everything in memory is properly saved to disk &c.
