Agreed- cornering can be improved.
There were a couple of occasions I wanted to measure ride height; one was the camper truck laden vs unladen and the other was when I lowered my Coupe. It was then I discovered I couldn't measure to the ground- even on what appears to be a decent concrete slab- because the measurements were all over the place, far too large to make the measurements of any value. It was then I discovered I could get better measurements by leaving the ground out of it, by measuring from the tops of the tires to the inner wheel well. The Coupe got lowered approximately 2" and it looks like your before-and-after.
P.S. The ground is still "in it" because the vehicle is parked on it, but the measuring errors are less. Concrete slabs are deceptively uneven.
