A manual transmission swap is a good deal, but wait to do it only when your stock automatic gets trashed, so you wouldn't be decreasing any residual resale value on your car.
Originally Posted by COcyclist
Please don't subject your TDI to a WVO conversion. Buy an old Mercedes for that if you must. A reputable biodiesel blend seems to work fine in these cars though.
Some older Mercs didn't even have to be converted at all to run safely on veg oils. Regarding biodiesel, check if your fuel lines are made out of some material compatible to biodiesel before you use it. Also, it's always better to change from regular Diesel to biodiesel gradually, otherwise the filters are going to clog due to sediments on the fuel tank and fuel lines getting dilluted in a high biodiesel content.
