Old 07-14-2008, 08:26 PM   #9 (permalink)
Mara
Originally Posted by dremd View Post
Nice!
You should try and spray some water on your condensers; I'll bet you can get some more cooling out of your system like that. Or if you were more ambitions you could do a geothermal heat exchanger and maybe cool your house near full time on solar.
Yes, the water on coil helps significantly. There was another post in "Saving@Home" forum where I discovered the mystery rubber plugs on my window AC units... and the purpose of those is to hold the condensed water and the fan blades splash it to the condenser coil. When I plugged the holes I saw almost 10% power consumption decrease! This agrees with my measurements with central AC unit which current consumption I measured using clamp on AC current meter with Cool-n-save system operation and not.
