Old 08-14-2014, 04:29 PM   #16 (permalink)
NothingFace
Citroen AX 1.5d - '93 Citroen AX
Diesel
90 day: 61.42 mpg (US)
Because any change to original spec is technically ilegal.
This means any change to suspension or engine if the police sees it they give you a fine and apprehend your cars documents, to get them back you need to go through a very strict inspection. And I aready have a different engine than original so It's better to keep a low profile since the engines are preety similar appearance wise.
If you want to have changes legal you need an engeneer to make a project and put all the changes in the cars documents.
Hopefully I can do this when I get my Masters Degree. but until then its not worth it since the fine is half of what I paid for the car in the first place, and I wouldn't whant to buy another one.
