Update: Registration/First Maintenance/Gauge Cluster Modifactions
We'll,
finally folks, after all my talk, here's some "walk".
First up was registration. I'll post a pic because of the appraised value.
HA!
Moving on...Maintenance work commenced as soon as I got the car back to the house.
I wanted to know exactly what I was "working with", so I ran a compression test. I'd like to think EricTheCarGuy, my favorite dude for Honda tutorials on YouTube, for the excellent advice on how to properly do compression testing.
First, I ran the tests on a cold engine ("dry" cylinders); then again with "wet" cylinders. Then, I drove the car for a couple of days with fresh oil and Engine Restorer additive. I then did the compression test once more, and achieved a bit more favorable numbers.
Overall, certainly not stats good enough to slap your momma about. However, they are within the working limits from Honda (135 psi, I understand, is the service limit). And most importantly, they are even. So, OK, now I don't feel too bad putting some time and money into this car.
The transmission got fresh Honda MTF. However, after a week of driving with it in, things still felt "crunchy". After some research, I decided to try Penzoil Syncromesh.
Man, glad I did! Transmission is shifting much better now. I highly recommend it vs. the Honda stuff. The "crunch" is almost gone entirely. The syncros are worn, but I'm hoping that using this stuff in regular intervals will help prevent a tranny re-build....or at least, drastically delay it.
Lastly for this first update, I did some research into the dash lighting. My cluster was rather dull, even with the illumination knob turned all the way up. I did an LED swap on my truck and liked the brightness of it, but do have some "hot spots" on the truck cluster. After some research, I found and decided to follow this awesome DIY linked below from a Honda-Tech user; amber halogen bulb swap. I'll be following his council for the climate control and remainder of the dash buttons + clock as well.
My EG speedo cluster & climate control in amber - done right - Honda-Tech
And so, off I set removing the cluster and setting up for the bulb swap.
But while I was in there, I decided to do some custom paint work as well. Time to break out an old friend for my model car days...
All sealed up and drying post-paint.
Used this stuff. Dries clear. Great stuff. Called "Canopy Glue". Used to glue plastic canopy's on model airplanes.
V.1 all done and in the car the next day:
Night-time pic w/ the amber effect (whole dash will be this color soon)
Later that evening, I had another idea/addition to add. Woke up the next day and added it. SO glad that I did. Feel like it really makes the cluster and ties everything together with the "green" mods for the dash. Added a "sweet spot" of green.
Here's the "sweet spot" in action, right near the area I shoot to lean burn within while highway cruising.
That's it for now. More to come.
Thanks for
eco-tuning in!
