Not to beat a dead horse but I also don't think that looks like 3.75". It looks like a little under 3", but definitely over 2".
Looks good, although I probably would not be able to tolerate a ride that stiff lol. With my 1.4" drop I'm barely able to not scrape speed bumps, and every curb probably takes a few thousandths of an inch off my front bumper via abrasion.
Since you've got all those adjustable suspension bits, have you thought of making the camber slightly negative? If you take turns quickly, the outside of your tires will wear down more. Since you don't have much suspension travel left, you'd need static camber despite your double wishbones to get closer to the "ideal" for handling. I think -1.5 degrees is pretty reasonable for a daily driver and is good for tire wear, or so I hear.
