Old 08-15-2014, 02:21 PM   #8 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by BikerModder View Post
Not actually! Premium engines burn the fuel slower during detonation...because you want to avoid predetionation if you ever tried this in an old corvette.. This is just to keep from taking the heads off your engine to put a thicker gasket. The only known other way to prevent predetonation due to high compression. Therby be as exact as you want. Now that is a heads job.
... did you even READ what I wrote? "...this mod increases effective combustion chamber volume by removing a section of spark plug thread, thereby lowering efficiency by lowering the compression ratio..."
BTW, premium fuels do not "burn slower" as such - they are merely more resistant to spontaneous combustion due to elevated pressures/temperatures.
