Originally Posted by kafer65
the pistons are still knocking around even when no fuel is going to them. They still produce friction with the cylinder walls and some pumping losses as well.
Yeah that makes sense. Honda also keeps firing the sparkplugs, so that's a little extra drain on the alternator/engine too. It's actually pretty amazing such an Accord can still keep moving on only 3 cylinders.
The Dodge Avenger had 4 or 6 cylinder options. Pretty much the whole car was built by Mitsubishi based-around the Eclipse platform. The only Dodge part was the transmission.
