Old 08-16-2014, 12:13 AM   #111 (permalink)
Bow
Old School Hashiriya
Bow's Avatar
Fred - '98 Nissan Frontier XE
90 day: 26.57 mpg (US)
A higher compression would be more suitable to run on ethanol.
Bow -- It's probably that 9.5:1 compression ratio. Alchohol likes high compression.
Edit: Like cRiPpLe_rOoStEr says.
yup... I did a metric $hit-ton of research before I swapped the 240SX to E85 in 2007... I had a healthy car with a healthy motor... I dropped in some 370CC injectors (from a Nissan SR20DET) and filled it up... its been running like a raped ape ever since... I put a wide-band O2 on it and had my Nissan ECU tweaking buddy in the passenger seat doing some real-time ECU monitering, he couldn't believe how "Stock" the fuel/timing maps looked. he leaned the ecu out a tad more than stock and I've been running it ever since.
I know higher compression is better for economy, but when I pull the 240 out, I'm not worried about Eco-driving... The built engine, with the individual throttle body injection and 11:1 CR on E85 should be a scream to drive in a light chassis.
Bow
