Originally Posted by Astro
I just collected my AC motor for the ev. It's a 132m frame 75kw rewound industrial motor which comes fitted with an encoder bearing. The encoder is 64 ppr. Will this be enough or will i need to add an external encoder with more pulses per revolution?
The encoder bearing is the same one as this eBay listing.
NEW SKF Sensor Bearing BMB 6206 064S2 UA002A Electric Motor Bearing | eBay
75kw rewind in a 132m frame - is there a typo there? My google search gives a 7.5 KW/10 hp motor, about 20 inches long, 165 lbs, 1800 rpm, 60 hz, in a D132M frame size.
I tried to shoe-horn a 30 HP, 575VAC 286T frame 3 phase AC direct drive into an S10. The motor weighs over 600 lbs. I was not successful
