Old 08-16-2014, 02:43 AM   #28 (permalink)
woodsrat
Beginner Ecomodder
It's AC and I use a $15 generic voltage regulator I get from Tucker Rocky to keep from overpowering the lights. I made my own simplified wiring harness and don't run a battery. I'm using an $8 Harbor Freight rubber tractor light on the front and a $10 LED tail light from eBay. The lights dim a tiny bit at an idle but as soon as I give it any throttle at all they get nice and bright. I work the second shift and come home through the country where it's really dark but the tractor light gives me plenty of light. A friend has the same setup on his step-though but runs two of them side-by-side for a "Baja" look and they work great.
I've used this setup for two years and it's been stone reliable with absolutely no failures.
The Following User Says Thank You to woodsrat For This Useful Post:
PeterS (08-16-2014)
