Old 08-16-2014, 06:14 PM   #903 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by thingstodo View Post
Sounds like a good application. I'll check around and see if one of the local (in Canada at least) Highlander Hybrids has had a tree jump out in front of it ... and become a source of parts (salvage wreck).
100 lb for the motor, gearbox and differential is AMAZING! I may even call Toyota and ask what a replacement costs. Likely $20K but I should ask
If you can find a junked Highlander Hybrid or Lexus equivalent, you can get these REALLY cheap! I'm talking a few hundred dollars, because no one knows what to do with them.
I must warn you, a big downside is the voltage they want to run at - think 2nd generation Prius. about 450VDC > 650VDC. I did find a thread where a guy tried to use one of them (sorry, I don't have the link) and did get it to work, at something like 200V or 300V. However, he was very dissappointed with the performance. (obviously)
The Following User Says Thank You to e*clipse For This Useful Post:
thingstodo (08-17-2014)
