Old 08-16-2014, 10:16 PM   #12 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by 101Volts View Post
The point is: Little kids including ones who aren't closely related who may end up getting to a car while I'm not looking. I've seen at least five Rescue 911 episodes (Which are re-enactments of actual events though they did dramatize them a bit) in which little kids played around with car transmissions while the cars were on:
There are 250,000 registered passenger vehicles in the US. The show is likely based on at least 10 years worth of cases. At that rate, statistically, you've got a 1 in 500,000 chance of this happening.
Transmission and clutch interlocks (for manuals) aren't required elsewhere in the world.
But an interlock is only a solenoid. You'd need to find something like a spring loaded shaft that locks the shifter, the solenoid, some wire, fuse and a relay. Start at the junk yard. Newer interlocks prevent you from removing the key if the car's not in park, that would be harder to do.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
101Volts (08-16-2014)
