I had the same problem with the SuperMID kit, never got it ironed out.
I suspect it was because I had the vss and inj wires switched. Double-check them Ben!
Triple-check them!
Do it now!
But yeah, make sure you don't have anything too whacky for vss/mileage parameter. The 8204 is pretty much spot-on if you're running stock diameter tires.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
