What about using washers and some copper grease to lift those plugs a few mm?
A 3 mm thick washer would add about 1 cc(*), that's more than you can get by chopping the thread.
At 333 cc per cylinder and a (guesstimated) compression ratio of 11:1 that would reduce the compressed chamber area (of 30.3 cc) by 3.3 %; it would reduce the compression ratio to about 10.6:1.
And when it gets really cold and your car does not start well anymore you can still just get the washers off and get moving again.
(*) of course that depends on the thread width. Assuming 18 mm here.
